• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Member
    SWModeller
    Pattern load
    190 Views, 1 Replies
    08-30-2011 08:47 AM
    How to practically apply pattern load  from specially loads for multi-span slab in Robot 2011?
    Is there any limit for slab geometry/layout when use pattern load method?
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Pattern load
    08-30-2011 11:58 PM in reply to: SWModeller
    You can try to define several live load cases with surface loads on a contours (one load in each of the load case) and then generate either automatic or manual combinations using the combination wizard (Loads > Automatic Combinations). The limit of combinations can be set in Job Preferences.
    Artur Kosakowski
    Support Specialist
    Product Support
