• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Distinguished Contributor
    Accepted Solution
    Panel load distribution
    238 Views, 5 Replies
    01-04-2012 07:56 AM
    Hi All,
    I am trying to analyze a structure using a unidirectional slab without f.e.. The verification of the structure give always the same advice " The he load  ...." as shown in the picture.
    The distribution of load seems anyway correct as shown in the picture.
    Any suggestion, How I can understand if and where the things are going wrong ?
    Please use plain text.
    Product Support
    Re: Panel load distribution
    01-04-2012 08:30 AM in reply to: GabrieleNovembri1027
    On my simple model everything works fine.
    Please send me your model
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    01-04-2012 10:18 AM in reply to: RG_Adsk
    Hi Rafal,
    You will find attached the RTD file of the part of the model that causes the error. It is portion of a very big structure and I have isolated the part with the problem as shown in the picture (the attached file is only a little part of the substructure in the picture). I have created constraints and so you can run the analysis. The selected panels give the error.
    Product Support
    01-05-2012 01:15 AM in reply to: GabrieleNovembri1027
    You are right. Loads are generated correctly but the misleading (in this case) warning message is displayed.
    One hint: if you want to neglect some bars in claddings loads generation use Geometry \ Additional Attributes \ Loads Distribution Options -> .... Ignore
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    01-05-2012 02:36 AM in reply to: GabrieleNovembri1027
    01-05-2012 02:37 AM in reply to: GabrieleNovembri1027
    Hi Rafal,
    Thanks a lot.
