• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    Bauskas
    Panel edge meshing ordeal
    184 Views, 2 Replies
    03-09-2012 11:47 AM
    I always tend to blame my crappy models for panel edge meshing problems. I try to use model correction only on the late stages of model development to prevent garbling and inconsistence of coordinates / nonplanar panels.
    Yet this one hasn't subjected to double pass of model correction. I also tried to redefine the contour multiple times. all failed, not to mention that this all is obviously a non-optimal effort spending.
    Mesh after several remodels and 1st model correction:
    Mesh after 2nd model correction:
    Are there any workflow hints to prevent the workload-heavy remeshing and remodeling?
    TIA
     Model (zipped):
    http://goo.gl/7KmkJ
    Please use plain text.
    Moderator
    Romanich
    Re: Panel edge meshing ordeal
    03-09-2012 10:40 PM in reply to: Bauskas
    Hi Alex,
    Try to use this meshing settings:
    And you will receive nicely mesh:
    Valued Mentor
    tony.ridley
    03-10-2012 07:00 AM in reply to: Romanich
    gun
