• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    tony.ridley
    Accepted Solution
    Panel defaulting to curtain wall
    161 Views, 6 Replies
    02-06-2012 05:46 PM
    Robot Dudes
    I've had a problem in Robot where I modify the geometry of a panel manually (click on the panel, then in object inspector click "geometry", then use the table function to modify).
    After I click "accept" and the panel then visible chages shape on the screen, it automatically becomes a Curtain Wall, thus loosing it's finite element properties...................
    Is this a common error reported?
    I think it may be similar to what AlexOpus is experiencing..........
    http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Floor-Slab-won-t-mesh/td-p/3297517
    Cheers,
    Tony
    Product Support
    Artur.Kosakowski
    Re: Panel defaulting to curtain wall
    02-07-2012 12:15 AM in reply to: tony.ridley
    Tony,
    This is the kind of change that I do very often and it has never happened (I have also tried this now). Please send me the file where this happened and tell me which panel you edited.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    tony.ridley
    02-16-2012 04:03 AM in reply to: Artur.Kosakowski
    Strangely enough the problem does not seem to occur at the moment.  New service pack maybe?
    Anyway if I notice it again I will let you know.
    Cheers,
    Tony
    AlexDT
    02-16-2012 04:42 AM in reply to: tony.ridley
    Could this be te problem? (see attached picture)
    Student at the Rotterdam University of Applied Sciences
    Graduating at de Jong Gortemaker Algra architects and ingenieurs
    tony.ridley
    02-16-2012 01:29 PM in reply to: AlexDT
    Alex
    Thanks, but I don't think this is why.  It was defaulting back to a curtain wall, which is a panel by definition anyway.
    Cheers,
    tony.ridley
    02-27-2012 08:00 PM in reply to: Artur.Kosakowski
    Artur,
    It's happening again.......
    I'll send you the model in a private message.
    Cheers,
    Product Support
    Artur.Kosakowski
    02-28-2012 06:21 AM in reply to: tony.ridley
    Tony,
    Thank you for movie and the file. We will investigate what actually happens.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
