• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Contributor
    Panel contour points modification (API)
    371 Views, 23 Replies
    04-12-2012 10:51 PM
    Is there any way to present panel contour points (coordinates X, Y, Z) in a table like the table available for nodes?
    I do not want table for each individual panel, but a table which presents all contour points for all defined panels in a model on one sheet.
    This could be helpful for fast correction of the contour points coordinates, especially in cases without precise geometry where the 9th decimal place at a coordinate makes all the difference between a good or bad mesh.
    Please use plain text.
    Valued Mentor
    tony.ridley
    Re: Panel contour points modification
    04-12-2012 11:16 PM in reply to: sergey.churilov
    Product Support
    Artur.Kosakowski
    04-12-2012 11:20 PM in reply to: sergey.churilov
    No, this is possible only for one panel at a time but I would suggest considering the use of the detailed correction option and adjust the model either structural axes or indicated planes instead.
    See e.g. http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Detailed-Correction/m-p/3079956
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    04-12-2012 11:55 PM in reply to: sergey.churilov
    @Tony
    Hi Tony, I have been reading many of your post and I found out that we have come to the same problems in using Robot. I have been using Robot for 10 years, but some of the questions/problems still remain unsolved even in the latest releases.
    Anyway, I will try and use the macro excel file that were provided and let you know my experience
    @Artur
    This option works sometimes, but not always. The problems about contour points misalignment still remains on some panels.
    Valued Mentor
    tony.ridley
    04-13-2012 07:04 AM in reply to: sergey.churilov
    I run the spreadsheet in the link, but I add a few columns to fix the rounding issues.
    ie =fixed(cell,3)
    then i replace the original columns in the spreadsheet before I hit update.
    I use it on an almost daily basis and find it works really well.
    Tony
    Product Support
    04-13-2012 07:26 AM in reply to: tony.ridley
    Is this general improvement? If so maybe we can update xls ?
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Valued Mentor
    tony.ridley
    04-13-2012 07:32 AM in reply to: RG_Adsk
    If the problem where rounding of decimal points for node co-ordinates is not linked to the user defined job units is not fixed in future Robot versions, then yes.  (sorry still havn't used 2013)
    If not, then the spreadsheet needs an update to include a rounding feature.  I have already done this though, shortly after you provided it.  This panel geometry sheet you made is one of my favourites.  Gets used almost daily.
    Tony
    Product Support
    04-13-2012 07:45 AM in reply to: tony.ridley
    Rounding is not impemented but... thru API it can be done.
    I will see. :-)
    Nice to hear that.
    Update xls and share.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Valued Mentor
    tony.ridley
    04-13-2012 07:58 AM in reply to: RG_Adsk
    Yes Sir.
    Monday!
    too late on Friday now to make the brain do this
    Active Contributor
    04-13-2012 08:09 AM in reply to: tony.ridley
    Please do so. I tried the sheet provided in the other post.
    It works perfectly. Its a miracle. Thank you so much.
    BTW is there any Robot open source manual or tutorial available to download?
    This just imposed many ideas I would like to implement for other analysis needs.
