Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Panel contour points modificati on (API)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is there any way to present panel contour points (coordinates X, Y, Z) in a table like the table available for nodes?
I do not want table for each individual panel, but a table which presents all contour points for all defined panels in a model on one sheet.
This could be helpful for fast correction of the contour points coordinates, especially in cases without precise geometry where the 9th decimal place at a coordinate makes all the difference between a good or bad mesh.
Re: Panel contour points modificati on
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Sergey
See this thread
Cheers,
Tony
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No, this is possible only for one panel at a time but I would suggest considering the use of the detailed correction option and adjust the model either structural axes or indicated planes instead.
See e.g. http://forums.autodesk.com/t5/Autodesk-Robot-Struc
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
@Tony
Hi Tony, I have been reading many of your post and I found out that we have come to the same problems in using Robot. I have been using Robot for 10 years, but some of the questions/problems still remain unsolved even in the latest releases.
Anyway, I will try and use the macro excel file that were provided and let you know my experience
@Artur
This option works sometimes, but not always. The problems about contour points misalignment still remains on some panels.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I run the spreadsheet in the link, but I add a few columns to fix the rounding issues.
ie =fixed(cell,3)
then i replace the original columns in the spreadsheet before I hit update.
I use it on an almost daily basis and find it works really well.
Tony
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is this general improvement? If so maybe we can update xls ?
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
If the problem where rounding of decimal points for node co-ordinates is not linked to the user defined job units is not fixed in future Robot versions, then yes. (sorry still havn't used 2013)
If not, then the spreadsheet needs an update to include a rounding feature. I have already done this though, shortly after you provided it. This panel geometry sheet you made is one of my favourites. Gets used almost daily.
Tony
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Rounding is not impemented but... thru API it can be done.
I will see. :-)
Nice to hear that.
Update xls and share.
Rafal Gaweda
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes Sir.
Monday!
too late on Friday now to make the brain do this
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please do so. I tried the sheet provided in the other post.
It works perfectly. Its a miracle. Thank you so much.
BTW is there any Robot open source manual or tutorial available to download?
This just imposed many ideas I would like to implement for other analysis needs.
