Panel Modification
Panel Modification
stroxy
Panel Modification
stroxy
I have a recatangular panel, representing a raft foundation.  I want to modify the area under the lift (elevator) core walls by dropping it deeper (to accomodate lift equipment) , what is the best workflow to achieve that,short of remodelling the whole panel from scratch?
Artur.Kosakowski
Autodesk Support
Autodesk Support
1. Create the opening within the lift area inside the existing raft foundation
2. Create a panel of the size of the opening below the existing raft foundation
3a. Create vertical panels to connect edges of the opening with edges of the newly created panel
or
3b. Use rigid links to connect nodes generated along the edges of the opening with the corresponding nodes of the panel you created below the opening
Artur Kosakowski
HoshangMustafa
Hi
Can't core walls be extended to the newly created panel?
Artur.Kosakowski
Autodesk Support
Autodesk Support
In general any vertical panel can be 'extended' to a new level but I'm not sure if I understand this particular design situation correctly.
Artur Kosakowski
HoshangMustafa
Hi Artur
I mean:
stroxy wrote in the first message:
I suggest that Instead of
you can write:
3a. extend the lift (elevator) core walls to edges of  the newly created panel.
Isn't it better to extend the lift core walls rather than creating vertical panel to conncet edges of the opening with edges of the newly created panel?
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'd say it depends on what is easier to do for you and the next steps you want to make such as:
- accessing results (e.g. reduced results for panels)
- definition of stories
- thickness of the part of a wall below and above the raft foundation
- application of loads
Artur Kosakowski
