Panel Edge Modification
stroxy
Message 1 of 14
stroxy
Is there a way to divide a panel edge without dividing the edge on the opposite side of the panel?
Is there a way to join panel edges that have been divided?
Replies (13)
Message 2 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Here you are.
See also: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/editing-slab-contour-geometry/m-p/3223160/hi...
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 14
How to select panel edge? When I click on edge, only whole panel selected
Message 4 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try these steps:
Artur Kosakowski
Message 5 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @stroxy
Here you can find the macro to delete intermediate points automatically.
Rafal Gaweda
Message 6 of 14
Please try to divide top edge for this one in atteched file
Message 7 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
H @Anonymous
I assume that what you really want is the control over meshing. If so try these steps:
Artur Kosakowski
Message 8 of 14
Rafacascudo
I am not sure you can do that because that edge is an arc segment.
What you can do is redo the panel increasing the numer of sides on arc discretization.
Rafael Medeiros
Message 9 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Rafacascudo
The similar effect can be obtained in this way:
Artur Kosakowski
Message 10 of 14
Rafacascudo
Yes , sure , That´s what I meant by "redo" Smiley Happy
Rafael Medeiros
Message 11 of 14
Hi, i tried dividing a wall in order to obtain better discretization of linear reactions, but it´s not working:
After aplying the Divide Tool to the edge and assigninn distance = 1m, nothing changes. I´m using a Wall with Shell model calculation.
Please i would appreciatte some help, my posts generally are not answered.
Thanks!.
Message 12 of 14
Rafacascudo
unmark "generate... "
Rafael Medeiros
Message 13 of 14
I did, but dindn´t succeed. Model atacched in case you wanna check.
Thanks.
Message 14 of 14
Rafacascudo
set the "divide" dialog as shown,select/click the desired edge to be designed and it will ask you if it is the edge or the whole panel(all edges) to be divided . select the edge and click OK.
Rafael Medeiros
