• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    Accepted Solution
    New profiles in Section database
    940 Views, 9 Replies
    05-11-2012 03:09 PM
    I am creating new profiles in Section database, Are welded, these profiles do not exist in international catalogue. There are several parameters to be inserted, but does not exist in "help" the meaning of all of them.
    I would like to receive the meaning of each parameter and also what are those that obligatorily must be completed so that the profile works perfectly on Analyse of Robot Structure.
    TKs,
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: New profiles in Section database
    05-13-2012 11:52 PM in reply to: jonatas.decampos
    Please check http://docs.autodesk.com/RSA/2012/ENU/filesROBOT/GUID-66A2E6F7-AE2B-44F7-96BD-49BFBBAC8F4-1627.htm
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    05-14-2012 06:27 AM in reply to: jonatas.decampos
    There are many more parameters that are not in this table.
    Product Support
    Artur.Kosakowski
    05-14-2012 06:51 AM in reply to: jonatas.decampos
    They describe the shape of the section and are shown on the picture of the section itself. They depend on the section shape and you can use one of the existing section types as the reference. For the complete list of section symbols check message 11 from http://forums.autodesk.com/t5/Autodesk-Robot-Structural/How-to-create-thin-walled-sections/td-p/3107... please.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    05-25-2012 01:09 PM in reply to: Artur.Kosakowski
    Thanks for the information, but I still have doubts in some parameters.
    You could tell me what is its meaning:
    SURF
    GAP
    HAS_MATS
    IS_THIN
    GAMMA
    And also I do not have these values to my profile you can tell me how can I calculate.
    TORS (Wx)
    SHEAR_QY (Wy)
    SHEAR_QZ (Wz)
    Tks,
    Product Support
    Artur.Kosakowski
    05-28-2012 01:11 AM in reply to: jonatas.decampos
    SURF - painting area
    GAP - distance between profiles used for compound sections
    HAS_MATS - indicates composite section (more than one material)
    IS_THIN - thin walled section (not used)
    GAMMA - defines the orientation of the main axes (see e.g. CAEP family)
    TORS (Wx) - for typical sections you can use the formulas from the attached documnet
    SHEAR_QY (Wy) - as above or can be calculated by the Section Builder module
    SHEAR_QZ (Wz) - as above
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    08-09-2012 07:49 AM in reply to: jonatas.decampos
    Missing one last thing. How can I calculate the SURF (painting area).
    Thank you
    Product Support
    Artur.Kosakowski
    08-09-2012 08:06 AM in reply to: jonatas.decampos
    Measure the outer line of the section contour (sides, top and bottom; the parts that you would paint e.g. for fire resistance) and multiply it by a unit of length declared for the section database.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Member
    10-09-2012 01:08 PM in reply to: Artur.Kosakowski
    Thank you for the info All were very useful.
    I arrived at a point that I need more formulas (Ax, Ay, Az, Wx, Wy, Wz).
    To calculate profiles of other geometries.
    Channels (C), angles (L), Drawers (Quad), XL.
    I put the PDF attached.
    Tks,
    Jonatas
    Product Support
    Artur.Kosakowski
    10-11-2012 12:32 AM in reply to: jonatas.decampos
    I'm sorry but I don't have them. For 'single shape' profiles you can calculate these values using the section builder of Robot (for compound profiles from your list As values can be assumed as double values calculated for the a single profile).
    You may try to search for:
    1/ CTICM, Revue Construction Metallique, Caracteristiques torsionelles
    des profils a parois minces, par S. Baraka
    2/ Ecole Polytechnique Federale de Lausanne, Institut de la construction
    metallique, Conception des structures metalliques - Partie C:
    Dimensionement des halles et batiments ; Deuxieme edition, 3e tirage
    corrige (decembre 1987)
    which cover  thin walled section calculations.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
