• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Contributor
    Need some help with purlin design
    132 Views, 1 Replies
    07-04-2012 08:52 AM
    i need to design a C form purlins for ceiling panels. Calculation scheme is as follows:
    - Pinned supports on the top flange on the ends of purlin
    - Loads on the low flange
    Question is, how to simulate the correct fixing of low flange (as it will be, when panels will be screwed)?
    See model attached.
    My design limits are- stresses from ULS - 200MPa, displacements in Z -30mm.
    Dont mind the stresses at the supports, joints will be designed in other way.
    Thank You.
    Please use plain text.
    Valued Contributor
    StefanoPasquini6790
    Re: Need some help with purlin design
    07-04-2012 10:16 AM in reply to: maronas
    Hi Maronas,
    you have to take care to the buckling behavior of your purlin. The top flange of C thin walled beam is compressed!!! See the eurocode 3 verification procedure for thin walled (cold formed) beam.
    Regards
