- Mute
- Permalink
- Report
I have been trying to use the new NBCC 2010 Equivalent Static Method in ROBOT 2014. I have a few questions/suggestions.
See the attached picture for reference to my points.
1. The S(Ta) given seems to be incorrect. It should =Fv*Sa(Ta) =0.1 see NBCC2010 CL4.1.8.4 (7).
2. The base of my structure is at 461.2m (defined at z=461.2), The results of the force distribution come up wrong because the 1st storey is cacluated to be at 4.57m+461.2m above the base level. Is there any way to make 461.2m be the "base level" so static forces are distributed correctly (using the formula V*Wi*hi/(sumWh)
3. I was wondering if there is any way to neglect the selfweight of the structure for this analysis? Currently the selfweight has been accounted for twice since I input the DL load case into the "load to mass conversion".
