• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Moving loads
    149 Views, 3 Replies
    10-18-2012 12:25 AM
    I have problem modelling a moving load, im doing a arbitrary vehicle, when I asign a value for FZ its later reduced when I look in the geometry section. I wonder if there is a factor somewhere reducing this value. I would like to use the asigned FZ-value for my calculations , not the reduced one.
    Anders
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Moving loads
    10-18-2012 12:46 AM in reply to: andlund
    Only if you define some reduction coefficients in the parameters of the route. Reading your question I don't think you defined them. Most likely the load has not been applied in full - I need the file to tell more. Please indicate which vehicle position to look at.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Re: Moving loads
    10-18-2012 01:33 AM in reply to: andlund
    Attached is the model, the vehicle load is case 72: Travers
    Product Support
    Artur.Kosakowski
    Re: Moving loads
    10-18-2012 02:39 AM in reply to: andlund
    Load direction should be vertical.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
