• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    mgaafar
    Accepted Solution
    Modelling Solid with Bars
    411 Views, 15 Replies
    01-17-2013 04:16 PM
    Hi, I am trying to model a precast slab with prestressed tandons inside. I was able to create the geometry, but when I started meshing, RSA does not mesh the solid with the Bars inside (no common nodes between the bars and solid blocks).
    is that common or I should do something to force RSA to feel the Bars inside the solid volumn?
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Modelling Solid with Bars
    01-18-2013 12:38 AM in reply to: mgaafar
    I would try the following approach:
    1. Define 'cross section' of the slab as a face of a solid
    2. Define nodes at the locations of tendons in the previously defined 'cross section'
    3. Mesh the 'cross section' (mesh should adapt to the defined nodes
    4. Use extrude to create meshed solids
    5. Select the tendon nodes in the 'cross section'
    6. Use translation with drag option marked to create tendons along the slab
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    mgaafar
    01-21-2013 07:59 AM in reply to: Artur.Kosakowski
    Thanks Artur, it worked but if you can please clarify my findings below plus other new questions just to confirm I did it right:
    1-when meshing the face, it does not show any mesh, so I assume it does that internally.
    2- in order to induce prestressing force in the tendons, I applied relative dilation on bars(tendons) with negative value as it wants to shorten the beam.
    3- will this method works if I start using object combinations so that it becomes complex solid with complex meshing?
    Product Support
    Artur.Kosakowski
    01-21-2013 11:52 PM in reply to: mgaafar
    Correct. You may create a panel instead of a face to see the meshing and then extrude it into solid
    I think this is correct (or apply TX temperature load to bars)
    No as the combination of objects will influence meshing of the final solid. In such cases the decision how to create the model will strongly depend on the shape of the solid itself.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    mgaafar
    01-24-2013 02:37 PM in reply to: Artur.Kosakowski
    Thanks again Artur, now I am facing another problem, after creating the precast slab and was able to make RSA mesh at the tendons, the model meshed nicely and ran the analysis properly. but I had to create a notch in the slab (thats what happened on site) and I wanted to see the stress concentration around the notch. I created a 3D box at the notch location and subtracted the main slab from the box and it worked fine. but  now when I meshed the solid, it took very long to mesh and the mesh is so bad and full of error.
    is there a better way to properly mesh the slab? please note that the notch is now very close to the tendon and I only modeled half the slab to reduce the model size.
    Thanks.
    Product Support
    Artur.Kosakowski
    01-25-2013 01:00 AM in reply to: mgaafar
    I would do this in the following way:
    1. Definition of two faces (the orange and and the grey above it)
    2. Meshing of faces
    3. Extrusion in 3 steps (the vertical orange line define the distances)
    4. Meshing and mesh freeze
    5. Deleting of the 'excessive' solid mesh elements
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    mgaafar
    03-21-2013 02:26 PM in reply to: Artur.Kosakowski
    So, Now the client wants to thicken the slab in a local area with a pyramid shape with some openenings  as per attached photo. It is easy to create the solid shape but it has been trying to mesh for more than 24 hours now and I do not know if the mesh will be ok or I will have to go through itterations. also Bar elements has to join to meshed nodes properly.
    is there an easy/faster way to the solid meshing? Like doing it in AUTOCAD and then import it to RSA? I created the model in CAD saved it to IGS, dxf and .SAT and tried to import it hoping the solid will be meshed as per Artur post in this thread but it did not work:
    https://forums.autodesk.com/t5/Autodesk-Robot-Structural/Autocad-dwg-files-import/m-p/3181550/highli...
    Time is not on my side, I need an effecient and fast way to do this..please help.
    http://www.screencast.com/t/DueMivbnb
    Product Support
    03-22-2013 05:08 AM in reply to: mgaafar
    First run with ACIS - attached
    Now waiting for refined mesh.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    03-22-2013 06:12 AM in reply to: RG_Adsk
    After some time of meshing (a few hours :-( )  ~347000 FEs
    file here: http://www.4shared.com/zip/nGFUZNqj/PC_SLAB_MODEL-test_ACIS2.html
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Valued Contributor
    mgaafar
    03-22-2013 08:19 AM in reply to: RG_Adsk
    Thanks Rafal, just for curiosity, how powerful is your computer?
    and If I want to model bars inside the concrete mass (Solid) and ensure that RSA will connect the mesh noddes to the bars, is it straight forward or there is a tweek around it?
    Thank you very much again for your help, much appreciated
