Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Modelling RC beam with slabs connecting at different levels
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What would be the best way to model a beam with a slab connecting on the upperside on one side and a slab connecting to the bottem end on the other side. Almost like a Z shaped scenario or more precicely a beam at a suspended pool edge with the pool base on one side and the deck slab on the other?
Re: Modelling RC beam with slabs connecting at different levels
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
1. Model the beam as a vertical panel
2. Model the beam in-between the horizontal panels with the same number on nodes along it as generated on the edges of the slabs. Connect the nodes with rigid links or short vertical bar elements.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Would I need to divide the supporting columns at the levels where the slabs frame into the beams?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm not sure if I can imagine the layout of your structure correctly. Could you make some sketch please?
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Artur
please find sketch attached
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is not necessary (unless you find it more useful for e.g. reinforcement calculations or reviewing of the results etc.) as any node defined along a bar element divides it into smaller calculation elements. This is similar to e.g. a beam defined at the level of a slab.
Artur Kosakowski
Support Specialist
Product Support
