Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Modeling a composite structure
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm trying to model a SlimFloor deck in a composite structure (composite columns and beams).
So my problem is on how to get the most apoximate properties for the Integrated floor beam (It's an asymemtric beam) essencialy on it's inertia.
The same problem occurs on the composite columns. Should I just create a bar with the properties for the composite sections or is there another way of moddeling it ?
The floor deck as the same problem, on the FE THICKNESS definition, it's available a slab on a trapezoidal plate, but it seams that it just models the concrete elastic properties, not the contribuition on the plate. In a SlimFloor deck, the height of the slab is significant, so the contribution of the trapezoidal plate is important. What is the best way on modeling this ?
Luís Correia
Re: Modeling a composite structure
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Any sketch would be appreciated.
Either you can calculate properties by your own and input them in section data fields or create section in Section Builder module and thsi module will calculate properties
Rafal Gaweda
Product Support
