• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Contributor
    Mode shape vectors
    340 Views, 11 Replies
    04-26-2012 03:29 AM
    Hi to all,
    How do you present mode shape vectors from each mode after performing modal analysis?
    I would like to compare the mode shape vectors from numerical analysis with experimental analysis and establish the Modal Assurance Criterion (MAC).
    Please use plain text.
    Valued Mentor
    tony.ridley
    Re: Mode shape vectors
    04-26-2012 03:38 AM in reply to: sergey.churilov
    Do you mean the mode shape diagram?
    Or a numerical representation?
    Active Contributor
    04-26-2012 03:44 AM in reply to: tony.ridley
    Numerical representation with values.
    Product Support
    Artur.Kosakowski
    04-26-2012 04:00 AM in reply to: sergey.churilov
    Press the RMB on the table with results of modal analysis and select table columns. Switch to the Eigenvectors tab.
    Artur Kosakowski
    Support Specialist
    Product Support
    New Member
    09-18-2012 05:01 AM in reply to: sergey.churilov
    i didnt undesrstand what is RMB .in modalanalysis environment i am getting only frequency results. i cant see any table. i need to have mode shape vectors .kindly help me with this
    Product Support
    09-18-2012 05:07 AM in reply to: murali3131
    RMB - right mouse button
    Click on table using  right mouse button then select Columns....
    Rafal Gaweda
    Product Support
    New Member
    09-18-2012 08:51 AM in reply to: sergey.churilov
    i am working in autodesk inventor for modal analysis.i got first 10 modes.but i need to have mode shape vectors to compare with experimental results.i am attaching image of my result.please suggest looking at the figure.
    Product Support
    09-19-2012 12:29 AM in reply to: murali3131
    This is Robot forum, not Inventor.
    Inventor http://forums.autodesk.com/t5/Autodesk-Inventor/bd-p/78
    Rafal Gaweda
    Product Support
    Active Contributor
    01-11-2013 05:33 AM in reply to: RG_Adsk
    To vertify my structure i have used matlab and plottet the eigenvectors. I am trying to compare the results from robot with the results from matlab. is there a smart way to get the eigenvectors ou from robott.. all i seem to get are -0 +0 and  1 -1 ?
    Active Contributor
    01-11-2013 05:39 AM in reply to: oyvinkle
    I was also wondering if Robot take into acount crackling of the concrete by code reduction factors for shear and flexular deformation when preforming a modal analysis?
