Mode shape vectors
Mode shape vectors
sergey.churilov
Message 1 of 14
Mode shape vectors
sergey.churilov
Hi to all,
How do you present mode shape vectors from each mode after performing modal analysis?
I would like to compare the mode shape vectors from numerical analysis with experimental analysis and establish the Modal Assurance Criterion (MAC).
Replies (13)
Message 2 of 14
Do you mean the mode shape diagram?
Or a numerical representation?
Message 3 of 14
sergey.churilov
Numerical representation with values.
Message 4 of 14
Artur.Kosakowski
Autodesk Support
Autodesk Support
Press the RMB on the table with results of modal analysis and select table columns. Switch to the Eigenvectors tab.
Artur Kosakowski
Message 5 of 14
i didnt undesrstand what is RMB .in modalanalysis environment i am getting only frequency results. i cant see any table. i need to have mode shape vectors .kindly help me with this
Message 6 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
RMB - right mouse button
Click on table using  right mouse button then select Columns....
Rafal Gaweda
Message 7 of 14
i am working in autodesk inventor for modal analysis.i got first 10 modes.but i need to have mode shape vectors to compare with experimental results.i am attaching image of my result.please suggest looking at the figure.
Message 8 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
This is Robot forum, not Inventor.
Inventor http://forums.autodesk.com/t5/Autodesk-Inventor/bd-p/78
Rafal Gaweda
Message 9 of 14
To vertify my structure i have used matlab and plottet the eigenvectors. I am trying to compare the results from robot with the results from matlab. is there a smart way to get the eigenvectors ou from robott.. all i seem to get are -0 +0 and  1 -1 ?
Message 10 of 14
I was also wondering if Robot take into acount crackling of the concrete by code reduction factors for shear and flexular deformation when preforming a modal analysis?
Message 11 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
See below
Rafal Gaweda
Message 12 of 14
Rafal.Gaweda
Autodesk Support
Autodesk Support
No , reduce E or section properties by your own
Example:
Rafal Gaweda
Message 13 of 14
Regarding the Eigenvectors, what is the normalization criteria used? Are all the components of the eigenvector normalized individually, or are they normalized relative to eachother? If they are relative, how is the relation between length components and rotation components taken into account?
Jose
Message 14 of 14
Pawel.Pulak
Autodesk Support
Autodesk Support
The components of the eigenvector are normalized relative to each other.
The relation is "unit independent" because values of rotation components correspond to tangents of appropriate rotation angles.
Pawel Pulak
Technical Account Specialist
