• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    Modal with automatic definition of seismic case
    189 Views, 3 Replies
    11-15-2012 12:41 AM
    Spoiler
      I would like from someone that has used the definition of the load case “Modal with automatic definition of seismic case“ to illustrate the options of this method.
      In the “Definition of seismic case group for the direction”, if for instance someone chooses the option X-Y-, does it mean that a simultaneous excitation is taking place in both directions of -X and -Y? And so, what does the title of the automatically generated load case: “Seismic EC8 Exc X-Y-Direction X” (and also “Seismic EC8 Exc X-Y-Direction Y”) means?
      Is the definition of eccentricities getting involved in this title?
      Thank you.
    Please use plain text.
    Product Support
    Re: Modal with automatic definition of seismic case
    11-15-2012 01:19 AM in reply to: Tuctas
    This part of this window corresponds to eccentricities, not excitations.
    THis X-Y- means both eccentritcities in negative X Y direction considered
    Excitations here:
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Valued Contributor
    11-15-2012 01:25 AM in reply to: Tuctas
      Thank you,
      You confirmed what i was already thinking about that.
      So, the title: "“Seismic EC8 Exc X-Y-Direction X” isn't correct. It should be: "“Seismic EC8 Ecc X-Y-Direction X”. The Exc must be replaced by Ecc.
    Product Support
    11-15-2012 01:51 AM in reply to: Tuctas
    Ok,thanks for reporting.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
