• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    bjornhgr
    Missing labels in Maps on Bars
    378 Views, 9 Replies
    12-20-2011 06:09 AM
    Hi.
    I'm trying to display normal forces in cross bracings in a steel frame structure in a readable way. I want to display an elevation with normal forces and labels on each bar. trying to use the Maps on Bars function I get _some_ of them, but never all of them at once. Why is this so hard, and is there anything I can do to fix it? It's driving me nuts. I've tried zooming in and out, but there are always some forces missing...
    Please use plain text.
    Product Support
    Re: Missing labels in Maps on Bars
    12-21-2011 02:17 AM in reply to: bjornhgr
    What about using Labels?
    HInt below:
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Valued Contributor
    bjornhgr
    01-18-2012 05:09 AM in reply to: RG_Adsk
    Hi.
    This problem was put on hold along with my project before christmas. Now I'm back at it, and the problem remains unsolved. I know about moving labels, but it doesn't help much when several bars meet (attached image). Using text I avoid this, but but it gets real messy (attached image), and it takes a lot of time cleaning it up when I have eight braces.
    Is there really no solution to this? I just want the maximum value for each bar, graphically displayed for easy reading...
    Valued Contributor
    mirko.jurcevic
    02-08-2013 03:03 AM in reply to: bjornhgr
    Maybe this can help:
    I've added additional nodes on bars and Robot displays "labels" (values) in nodes. See image attached.
    My question: is there any other way to display additional values for diagrams. Let's say that Robot displays diagram value at beggining and the end of the element but I want also to see value in the middle, or at any other place. Is there a way to display additional value without adding a node at that place?
    Something like when displaying maps for surface elements - there is possible to display value at specific point.
    INTELIKA
    Mirko Jurcevic MEng
    BIM Manager
    INTELIKA d.o.o.
    www.intelika.hr
    Product Support
    02-08-2013 04:08 AM in reply to: mirko.jurcevic
    No. As you mentioned - add nodes.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Valued Contributor
    mirko.jurcevic
    02-08-2013 04:31 AM in reply to: RG_Adsk
    That's bad.
    And what if I don't know in advance where I'll need to put nodes.
    Process would be:
    calculate model -> find places where you need additional values -> remember/write down positions of additional nodes -> add nodes -> calculate again -> find out that you missed something -> swear -> add nodes -> calculate again
    And imagine what if you need half an hour for each calculation.
    I don't know, there got to be an easier way to do this.
    And what when I right click to diagram value text and delete it? How can I get it back?
    INTELIKA
    Mirko Jurcevic MEng
    BIM Manager
    INTELIKA d.o.o.
    www.intelika.hr
    Valued Contributor
    mirko.jurcevic
    02-08-2013 04:41 AM in reply to: mirko.jurcevic
    I've found out: And what when I right click to diagram value text and delete it? How can I get it back?
    View -> Descriptions -> Restore Deleted Descriptions
    INTELIKA
    Mirko Jurcevic MEng
    BIM Manager
    INTELIKA d.o.o.
    www.intelika.hr
    Product Support
    02-08-2013 04:51 AM in reply to: mirko.jurcevic
    Use Detailed Analysis : http://screencast.com/t/uiKgsVAM0Ewd
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Valued Contributor
    mirko.jurcevic
    02-08-2013 05:53 AM in reply to: RG_Adsk
    Thanks, that's useful! :smileyhappy:
    Screen capture takes diagrams+table at the same time, which is good.
    But, I don't have that vertical blue bar for reading values.
    And, on my sample model, when I insert column in detailed analysis I get wrong direction of load forces.
    Look at the images attached.
    INTELIKA
    Mirko Jurcevic MEng
    BIM Manager
    INTELIKA d.o.o.
    www.intelika.hr
    Product Support
    02-08-2013 06:09 AM in reply to: mirko.jurcevic
    Thx for reporting. I will registser it for correction.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
