• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Contributor
    Minimum reinforcement in Reinforcent Designer
    251 Views, 3 Replies
    09-27-2012 10:23 PM
    When using the reinforcement designer for a floor plate to CP65, the only settings I can find regarding minimum reinforcement is as displayed in the attached illustration. Is there a way to see the input settings for minimum reinforcement or can you please let me know how it works?
    Could it be set up so minimum reinforcement correspond to the cracking moment for the slab?
    Cheers,
    Jesper
    Please use plain text.
    Product Support
    Re: Minimum reinforcement in Reinforcent Designer
    09-28-2012 12:31 AM in reply to: Jesper.Jensen
    No, Minimum reinforcement is given by the national code.
    Rafal Gaweda
    Product Support
    Valued Contributor
    10-03-2012 03:54 PM in reply to: RG_Adsk
    Is there a way I can change the input for this setting?
    Product Support
    10-04-2012 12:06 AM in reply to: Jesper.Jensen
    No, it is hardcoded.
    Rafal Gaweda
    Product Support
