Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Minimum reinforcem ent for columns according to code
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi
When I calculate reinforcement for columns, I only get the static required area and not the minimum area according to the code when that is governing.
Does Robot calculate the minimum reinforcement according to Eurocode?
If so, where can I see the result?
Kind regards
Peder
Re: Minimum reinforcem ent for columns according to code
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do you refer to RC Column Design module or RC Member theoretical Reinforcement one?
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am refering to the RC Member theoretical Reinforcement.
I am using structure type 'building design'.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The reinforcement table shows values of reinforcement which include the minimal reinforcement provisions (larger values are shown). The value of min. reinforcement is not listed separately yet you may try to define a dummy load case e.g. 0.1 self weight and use it for the design. This should return these values as the result.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I tried what you suggested but without any luck.
I am designing according to EC with the Norwegian annex.
According to pt. 9.5.2(2): As = max (0,10Ned/fyd, 0,002Ac)
However, the Norwegian annex is governing in this case where the limit is set as follows:
As = 0,2Ac x fcd/fyd < 0,5Ned/fyd but not less then 0,01Ac
The column I am testing is 300x600mm2 which should return the minimum value of 1800mm2.
As you can see from the picture above, there is a clear discrepancy between the two values.
Am I doing something wrong?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Could you send me the rtd file with this column as well as the screen capture of the discussed provisions from the Norwegian NAD for EC2 please?
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Introduced in SP4 for Robot 2103. Please check for the availability of this update at the beginning of the next week.
Artur Kosakowski
Support Specialist
Product Support
