• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Minimum eccentricity for steel simple columns
    217 Views, 2 Replies
    10-12-2012 08:40 AM
    How would we model minimum exccentricity for a simple beam-column connection.  i.e. 100mm+d/2 to indue some bending into the column following the collection of a simple beam?
    Most structural programs that I have used, will have an option to include this during analysis; however, the robot structural module simply calculates the column in pure axial with no bending.
    Any ideas?
    Many Thanks
    Andy
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Minimum eccentricity for steel simple columns
    10-15-2012 12:08 AM in reply to: esuffk
    Use the reduce length offset on the beam. The value of the offset (bending moment) will automatically follow the change in the column size.
    http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-63486561-1D79-4056-A945-890FD7CED7AB.htm
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    10-15-2012 12:18 AM in reply to: Artur.Kosakowski
    Many thanks for your response. I will give it a try later on today. Regards, Andrew Simpson
