• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Member
    Meshing problem - alignments and connections
    137 Views, 2 Replies
    01-09-2013 08:32 AM
    Hi I am tryin to model a steel tank using meshing.
    I am having a problem with making meshes that join at angles to connect so they act together. No matter what I do I can not make the platee that are at angles join correctly, even when i draw the new mesh at each individual node. Please see images below of example where this has happened, along with an atached file.
    Thank you for your time.
    Oscar Gaunt
    Please use plain text.
    Product Support
    Re: Meshing problem - alignments and connections
    01-09-2013 11:53 PM in reply to: OscarGaunt
    Are panels well connected on common edges? From first screen shot I can see they are apart.
    Send us model to check.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Member
    01-10-2013 01:14 AM in reply to: RG_Adsk
    Sorry problem solved now!
