• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Member
    pascal.bogdan
    Mesh+Bracket error?!
    737 Views, 2 Replies
    09-27-2011 12:42 AM
    I encountered today a thing that never happened in Robot. When using bracket for a beam that supports a shell slab which was meshed (lets say 0.5 m mesh size), at the end of the bracket the Fz value is very big, and this never happened in older version of robot. I checked old structures made with RSA v19 or 2010 and that issue didn't exist.
     Thanks in advance!
     regards,
     Bogdan
    LE: I attached the picture for the beam without the bracket
    Please use plain text.
    Product Support
    Re: Mesh+Bracket error?!
    09-27-2011 03:46 AM in reply to: pascal.bogdan
    HI,
    Turn off kinematic contrains in job preferences
    Rafal Gaweda
    Product Support
    Member
    pascal.bogdan
    09-27-2011 04:09 AM in reply to: RG_Adsk
    Thank you! Now it works as it should :smileywink:
