• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    Member consisting of multiple bars (for design)
    201 Views, 5 Replies
    05-22-2012 09:50 AM
    See attached picture
    I am trying to link two members (522 and 521) for design. The bottom node of the resulting member should be #1741 and the top #1740.
    However, when I go through the process of linking these bars to act as a single for design, the orientation switches. The resulting member has node 1740 as the bottom, and 1741 as the top.
    What have I done wrong? Is there any way of controlling this?
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Member consisting of multiple bars (for design)
    05-22-2012 11:43 PM in reply to: CameronEC
    Please attach the rtd file with these two bars .
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Member
    05-23-2012 06:40 AM in reply to: Artur.Kosakowski
    See attached for a model showing the bay with the columns I indicated earlier.
    Also, you can see that the combined section 9000 (and 9030) is defined top to bottom, while 9010 and 9020 are defined bottom up. I was hoping I could find a way to to control these definitions.
    File
    Product Support
    Artur.Kosakowski
    05-23-2012 06:56 AM in reply to: CameronEC
    I'm sorry but I'm not able to download the file from this location. Could you delete all but the part of the model with these bars and save such rtd file under a new name please? After compressing it you should be able to attach such created zip file. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Product Support
    05-23-2012 08:02 AM in reply to: CameronEC
    Got it.
    Rafal Gaweda
    Product Support
    Product Support
    Artur.Kosakowski
    05-23-2012 09:50 AM in reply to: CameronEC
    The origin is in the node that has got  a lower number. The way of controlling this is shown on the attached picture.
    Artur Kosakowski
    Support Specialist
    Product Support
