• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Valued Mentor
    AJA14
    Matrix is not positive definined
    250 Views, 5 Replies
    08-06-2012 11:03 PM
    Hi. I am trying to design a shoring system consisting of diaphragm walls with counterfort walls as stiffeners for a case at hand. I get instability problems and if i don't press escape I receive a dialog saying that the matrix is not positive definitive - critical load may have been exceeded. Could that be due to the location and direction of elastic supports. Or is it because I should be using a different solver. Any ideas or advice. Shoring System.png
    Ali Al-Hammoud
    Structural Design Engineer
    MZ & Partners Engineering Consultancy
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Matrix is not positive definitive
    08-06-2012 11:56 PM in reply to: AJA14
    This warning suggests that the load level is excessive (structure becomes unstable under applied load).
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Contributor
    aruser
    01-22-2013 01:20 AM in reply to: Artur.Kosakowski
    When getting this message I used to check the full note of Analysis->Calcultion report->full note and make sure that all the load cases are convergent. By doing this, despite the matrix message, could we assume that the calculations, forces, displacements etc are correct? Iguess so. Please confirm.
    Product Support
    Artur.Kosakowski
    01-22-2013 01:23 AM in reply to: aruser
    No, as the analysis may converge for the different state of equilibrium of the structure. You need to determine where you are with the current load level first.
    Artur Kosakowski
    Support Specialist
    Product Support
    Active Contributor
    aruser
    01-22-2013 01:34 AM in reply to: Artur.Kosakowski
    Sorry, could you explain yourself a little bit more. How can we do this you are explaining?
    Product Support
    Artur.Kosakowski
    01-22-2013 02:03 AM in reply to: aruser
    Try to run linear and  non-linear buckling analysis (with no P-Delta) for the case or combination which reports this issue and check the value the critical coefficient. Try to reduce the load and check if the original load converges with no warnings displayed and then investigate the deformation of the model and compare it with the one you have for the original load.
    Artur Kosakowski
    Support Specialist
    Product Support
