Material Properties (API)
Message 1 of 31
Is there any way to get tabulated data for all of the materials in the Robot database?  I searched in the program files / Robot 2013 but can't find it easily.
Tony
Replies (30)
Message 2 of 31
Rafal.Gaweda
Autodesk Support
Autodesk Support
Only as additional columns in Bars, Panels ro Quantity Survey tables
Rafal Gaweda
Message 3 of 31
Rafal.Gaweda
Autodesk Support
Autodesk Support
Or something for you 🙂 -> small API in Excell geting materials \ material data in the way you want.
Rafal Gaweda
Message 4 of 31
hahah ok thanks 🙂
So, without API, if a colleague wants to print a list of material properties for example - all concrete types - then he would have to draw many bars, then assign each one a material?  Then use the table you describe?
not a atext file somewhere here:
C:\Program Files\Autodesk\Autodesk Robot Structural Analysis Professional 2013
tony
Message 5 of 31
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example attached (materials used in model)
Rafal Gaweda
Message 6 of 31
Rafal.Gaweda
Autodesk Support
Autodesk Support
XML file = kind of text file, material databases names  : rmat*.xml
"c:\ProgramData\Autodesk\Structural\Common Data\2013\Data\Mate"
user section databases, material databases, etc.
Win 7 32- or 64-bit RSAPro:
C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\2013\
Rafal Gaweda
Message 7 of 31
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hint below
Rafal Gaweda
Message 8 of 31
Rafal.Gaweda
Autodesk Support
Autodesk Support
API, API, API...
Gift for You attached - whole database to Excel.
If you want only concrete materials  :
replace
Set RNA = RobApp.Project.Preferences.Materials.GetAll
by
Set RNA = RobApp.Project.Preferences.Materials.Get(I_MT_CONCRETE)
Rafal Gaweda
Message 9 of 31
Rafal,
You are THE man.
Cheers,
Tony
Message 10 of 31
dear all pro
i want to add one material to materials database
pl see image below for more detai
THANK ALL
Message 11 of 31
dimogrec
Message 12 of 31
Thank pro
But I want to add one more country to material database
can you help me?
Thank so much
Message 13 of 31
dimogrec
Fisrtly select Materials->"country database from which you want to copy material"->modification, then copy the values of material properties (into a paper or doc)
Then open your country database (the one you want to add the material) -> modification, select the type of material (concrete,steel..ecc) and then write a new name for your material, paste the values of material properties and then click add and ok
I don't know a faster way to do this
Message 14 of 31
Rafal.Gaweda
Autodesk Support
Autodesk Support
I think he wants to create completely new material database and attach it to Robot.
Rafal Gaweda
Message 15 of 31
Rafal.Gaweda
Autodesk Support
Autodesk Support
Example movie: http://screencast.com/t/9shu2LnMq0j
Rafal Gaweda
Message 16 of 31
YES , THANK PRO SO MUCH.
It's just what I had in mind
You are very pro RSAP.
Message 17 of 31
ledinhchinh0409
hi. @Rafal.Gaweda @Anonymous
Hi. I also have the same theme. I have added the definition of B22.5, Resistance: 13 MPa.
But when designing the Material properties there is Rb = 11.5 MPa. Can you help me. Thank you!
Message 18 of 31
ledinhchinh0409
hi. @Artur.Kosakowski
I think in this case, RSA is wrong, is not it?
Message 19 of 31
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @ledinhchinh0409
The Russian SINP code is a specific one as instead of providing formulas to describe the relationship between E and resistance it uses the tabulated values instead and gives no indication what to do when the concrete grade is not the one explicitly stated in the code itself. This is the reason adding new (different than specified in) concrete grades for SNIP may result in having unexpected results as program tries to interpolate among the values given in these tables.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 20 of 31
ledinhchinh0409
Thanks you verymuch.
So the definition of caculation options is not acceptable?
