• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    odysseasg
    Manual Calculations for Steel Design using API
    993 Views, 8 Replies
    12-14-2011 03:35 AM
    I'm trying to design a steel section using VB. I guess the procedure is calling the IRDimCodeService interface and the ModalEditManualParams method. I can not seem to access the IRdimCodeService (IRDimClient.GetRDimCodeService) as i can't implement IRDimClient.
    Can anyone help me with this?
    Please use plain text.
    Product Support
    Re: Manual Calculations for Steel Design using API
    12-14-2011 03:54 AM in reply to: odysseasg
    Hi
    Take a look at attached pdf
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Member
    odysseasg
    12-14-2011 04:08 AM in reply to: RG_Adsk
    Hello Rafal,
    Any ideas on how to access IRDimClient? Does it derive from IRDimServer? I cannot access it through RobotApplication.Kernel.GetExtension("RDimClient").
    Odysseas
    Product Support
    12-14-2011 04:10 AM in reply to: odysseasg
    I have never gone that far with API :-(
    I will do my best checking it.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Member
    odysseasg
    12-14-2011 04:18 AM in reply to: RG_Adsk
    Thank you Rafal, I appreciate that.Looking forward to a solution to this.
    Regards
    Product Support
    12-14-2011 07:49 AM in reply to: odysseasg
    IRDimClient - This interface is implemented by the external  COM codes (standards). It is not available in Robot.
    With the help of COM interfaces you can not call any of the windows.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Member
    odysseasg
    12-14-2011 07:58 AM in reply to: RG_Adsk
    So there's no way i can manually input Forces for the section design using the API (by accessing the dialog box shown in the attached file)?
    Product Support
    12-14-2011 08:03 AM in reply to: odysseasg
    No, not possible.
    Forces should be imported from model.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Member
    odysseasg
    12-14-2011 09:21 AM in reply to: RG_Adsk
    Ok, Thanks
