• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Member
    zhurukhin
    Accepted Solution
    Loads applied but displacements and deflections aren't shown
    80 Views, 2 Replies
    07-06-2012 05:35 AM
    Hi!
    I made calculation of my scheme.
    But it looks like only dead load was calculated.
    Results from all other loads (vertical and horizontal) give me zero values of forces, displacements and deflections.
    What could be the reason?
    With kind regards,
    me
    Please use plain text.
    Product Support
    Re: Loads applied but displacements and deflections aren't shown
    07-06-2012 05:47 AM in reply to: zhurukhin
    Check whether these cases are not set as auxiliary.
    Additional check:
    Press Normalize button and \ or change scale
    Fx scele : 500 or 100 and find the biggest value -> member
    Deformation :change scale -> find the place on structure where it is
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Member
    zhurukhin
    07-06-2012 06:19 AM in reply to: RG_Adsk
    I've found reason - model generation was swithed off.
    After I switch it on it works good.
    Anyway, thanx for reply.
