• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Accepted Solution
    Load to mass problem
    147 Views, 2 Replies
    02-20-2013 01:50 AM
    When I try to convert load to mass, the program converts the loads that are applied on bars only, not those on shell elements.
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Load to mass problem
    02-20-2013 01:56 AM in reply to: sedefass
    Create a new load case where you have only loads applied to shells. Run static analysis of this case and check that the load is applied correctly. Then in the modal analysis mark disregard density and convert only the new load case to mass. Run calculations and check the total mass in the results of modal analysis case. If it is 0 then send us this model.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    02-21-2013 05:23 AM in reply to: Artur.Kosakowski
    Thank you Artur!
