Load to mass conversion
Refaat
Advisor Advisor
Message 1 of 24
Refaat
Dear Sir
-  Which mass type (global mass & dynamic mass ) shall I use it for my model (concrete tower 21 floor )?
Shall I activate the mass in three directions (X,Y,Z) or only (X,Y) Because my building height = 75m ?
 Thanks in advance
Refaat
Accepted solutions (3)
Replies (23)
Message 21 of 24
Refaat
Dear Sir
I am very sorry to take a lot from your time.... I just want to confirm the information if possible .
Please , have a look to the attached capture , and correct me if I am wrong .
Refaat
Message 22 of 24
Refaat
Dear Sir
Refaat
Message 23 of 24
Rafal.Gaweda
Autodesk Support
Autodesk Support
Changing value in direction may give you the same effect but in fact it rescales whole spectrum so you may get different base shear depending on code requirements (min base shear etc) and then such base shear is multiplied by this factor. So it is recomended to use direction =1 then set factor.
Rafal Gaweda
Message 24 of 24
Refaat
Dear Sir
Thank you for your cooperation .
 Best Regards
Refaat
