• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Distinguished Contributor
    Accepted Solution
    Load to mass conversion
    620 Views, 23 Replies
    10-04-2012 12:02 AM
    Dear Sir
    -  Which mass type (global mass & dynamic mass ) shall I use it for my model (concrete tower 21 floor )?
    Shall I activate the mass in three directions (X,Y,Z) or only (X,Y) Because my building height = 75m ?
     Thanks in advance
    Refaat
    Please use plain text.
    Valued Mentor
    tony.ridley
    Re: Load to mass conversion
    10-04-2012 12:09 AM in reply to: refaat
    Most accurate is consistent I believe.  But we normally use lumped with rotations.
    If you disregard density there will be no mass participating in the modal analysis. Unless you add it back in via load to mass conversion.
    I would NOT disregard density, and also add 30% live load (or whatever percentage) to the load to mass conversion.  Normally can ignore Z direction.  If you add mass to global or dynamic the mass will be added to all dynamic cases.  If you specify the modal case only, it will only be added to that case.
    Product Support
    10-04-2012 12:10 AM in reply to: refaat
    Refaat
     http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Conversion-load-to-mass/m-p/3050232/highligh... - message 3
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    10-04-2012 02:28 AM in reply to: RG_Adsk
    Dear Sir
    I got confused about base shear coeff. ( as i see in the attached capture 01) you got this coeff. (1.74) by dividing (automatic / inactive ). Did you mean that the inactive case is the static linear case ?? (because as we know that the base shear scale is the ratio (0.85Vstatic/Vdyanmic) . as I used it in the capture 02 ,is it true or not ?
    Refaat
    10-04-2012 02:29 AM in reply to: RG_Adsk
    Dear Sir
    Pls , give me more explanation (  3 Selecting Global mass - converted masses will be applied to all dynamic cases and also can be used in inertia   forces (of course if such forces are applied on model)
      In my case , I will use (global mass ) in my model is Keya ?
    Refaat
    Product Support
    10-04-2012 03:32 AM in reply to: refaat
    Example:
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    10-04-2012 03:39 AM in reply to: refaat
    Refaat,
    Inactive means that results come directly from seismic calculation without base shear.
    Yes, true.
    One more remark: do not use "Use normalized values" checkbox.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    10-04-2012 04:23 AM in reply to: RG_Adsk
    Dear Sir
    Do you mean that ( Dynamic = globle + modal ) ? , and i have to use dynamic
    Rrfaat
    10-04-2012 04:35 AM in reply to: RG_Adsk
    Dear Sir
    As appears in the attached capture
    As I understand (T= structure period ) and what  about (reduction coeff.)?
    Refaat
    Product Support
    10-04-2012 04:35 AM in reply to: refaat
    Global means that converted masses will be considered in ALL dynamic cases in model (modal and footfall ones; other dynamic cases need to be run after modal case so they consider masses from precedent modal).
    My advise: use dynamic.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
