Linear Releases with API
Message 1 of 8
I'm trying to script some linear releases using the Robot API in C#, but can't seem to get my head around it. Can you please post an example defining a linear release?
What I'm trying to achieve is releasing all edges shared by two panels, but only on one of the panels to avoid getting to many DOFs.
Hope you are able to help me out,
Andreas
Replies (7)
Message 2 of 8
I think I'm getting closer to an answer myself. The following code runs perfectly, but doesn't seem to produce any releases on the edges. What am I missing?
IRobotLabel linearReleaseLabel = robotApplication.Project.Structure.Labels.Create(IRobotLabelType.I_LT_LINEAR_RELEASE, this.name);
RobotLinearReleaseServerlinearReleaseServer = robotApplication.Project.Structure.Objects.LinearReleases;
RobotLinearReleaseData linearReleaseData = (RobotLinearReleaseData)linearReleaseLabel.Data;
linearReleaseData.HX =
this.HX;
linearReleaseData.KX =
this.KX;
linearReleaseData.KY =
this.KY;
linearReleaseData.KZ =
this.KZ;
linearReleaseData.RX = toRobotLinearReleaseDefinitionType(RX);
linearReleaseData.UX = toRobotLinearReleaseDefinitionType(UX);
linearReleaseData.UY = toRobotLinearReleaseDefinitionType(UY);
linearReleaseData.UZ = toRobotLinearReleaseDefinitionType(UZ);
robotApplication.Project.Structure.Labels.Store(linearReleaseLabel);
RobotObjObjectServerrobotObjObjectServer = robotApplication.Project.Structure.Objects;
for (inti = 0; i < panelIndices.Count; i++) {
IRobotObjObject robotObjObject = (RobotObjObject) robotObjObjectServer.Get(i+1);
RobotObjPartMain robotObjPartMain = (RobotObjPartMain) robotObjObject.Main;
RobotObjEdgeCollection objEdges = (RobotObjEdgeCollection) robotObjPartMain.Edges;
for (intj = 1; j <= objEdges.Count; j++) {
RobotObjEdge objEdge = (RobotObjEdge) objEdges.Get(j);
if (objEdge.HasLabel(IRobotLabelType.I_LT_LINEAR_RELEASE) == 0) {
objEdge.SetLabel(
Message 3 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
try to add
robotObjObject .Update
robotObjObject .Initialize
to the end of if
Rafal Gaweda
Message 4 of 8
Hi Rafal,
Thanks for the reply... Unfortunatly it still doesn't work. The label is is created without any problems, nevertheless I tryed changing the label to a Robot native one:
objEdge.SetLabel(IRobotLabelType.I_LT_LINEAR_RELEASE, "pinned");
And I know for sure that the line of code is running, but it still doesn't work. Is this not the right way of applying a linerar release label to an edge?
Thanks again,
Andreas
Message 5 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
I need develeopers to check why SETLABEL and HASLABEL do not work for linear releases.
Rafal Gaweda
Message 6 of 8
Hi Rafal,
Have you got any clarification on this?
Message 7 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
I have not checked yet but operation by  labels (set , has) as you did works only for supports for objects.
For linear releases you should use:
robotApplication.Project.Structure.Objects.LinearReleases....
Rafal Gaweda
Message 8 of 8
Rafal.Gaweda
Autodesk Support
Autodesk Support
 private void button1_Click(object sender, EventArgs e)
            RobotApplication robotApplication = new RobotApplication();
            IRobotLabel linearReleaseLabel = robotApplication.Project.Structure.Labels.Create(IRobotLabelType.I_LT_LINEAR_RELEASE, "apirel");
            linearReleaseData.HX = 0;
            linearReleaseData.KX =0;
            linearReleaseData.KY =0;
            linearReleaseData.KZ =0;
            linearReleaseData.RX = IRobotLinearReleaseDefinitionType.I_LRDT_RELEASED  ;
            linearReleaseData.UX = IRobotLinearReleaseDefinitionType.I_LRDT_NONE;
            linearReleaseData.UY = IRobotLinearReleaseDefinitionType.I_LRDT_NONE;
            linearReleaseData.UZ = IRobotLinearReleaseDefinitionType.I_LRDT_NONE;
            RobotObjObjectServer robotObjObjectServer = robotApplication.Project.Structure.Objects;
            IRobotObjObject robotObjObject = (RobotObjObject)robotObjObjectServer.Get(1);
            int Numberofedges = robotObjObject.Main.Edges.Count;
            for (int i = 1; i <= Numberofedges; i++)
                if (robotObjObjectServer.LinearReleases.FindEdge(robotObjObject.Number,i) == 0)
                    robotObjObjectServer.LinearReleases.Set(robotObjObject.Number,i, robotObjObject.Number,1,"apirel");
            robotObjObject.Update();
            this.Close();
Rafal Gaweda
