• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Member
    Library structure error for French language when ACIER material is not available
    343 Views, 7 Replies
    08-07-2012 08:47 AM
    Hi   I downloaded trial version of ARSAP 2013
    je telecharger la version 2013 et je voulais faire quelque exemple, mais quand je choisie le icon de structure type, RSAP fait un message d'erreur de que je clic deux fois sur la structure que je veux choisir
    Please use plain text.
    Product Support
    Artur.Kosakowski
    Re: Mode expert et apilog dans RSAP 2013
    08-07-2012 11:49 PM in reply to: wadii.bouzemmi
    The message suggests that you tried to load one of the library structures. Could you check what materials (French or English/Eurocode) as well as section databases you have got set in Job Preferences? Mind that for French language ACIER material has to be available. In case it is missing add create it e.g. using Steel as the reference.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Member
    08-08-2012 11:00 AM in reply to: Artur.Kosakowski
    hi
    when i do this a have probleme, i think it is'nt good instaled!
    Product Support
    Artur.Kosakowski
    08-08-2012 11:58 PM in reply to: wadii.bouzemmi
    truss.PNGIn case some of bars (posts and diagonals) do not have assigned sections after you press OK (ignore any displayed warnings) select them and assign sections using the Sections dialog instead.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Member
    08-09-2012 07:07 AM in reply to: Artur.Kosakowski
    hi
    i use canada franch version, it is trial version, in picture the are what i have when i try to use tipical structure
    Product Support
    jad.dellel
    08-09-2012 07:48 AM in reply to: wadii.bouzemmi
    Bonjour,
    Comme indique' dans le message 5, il faut verifier la compatibilite' de la base des materiaux avec les preferences regionales:
    veuillez verifier que vous avez bien les parametres affiches dans les captures ci-dessous:
    Jad DELLEL
    Structural Engineering Product Support Autodesk, Inc.
    Member
    08-09-2012 01:20 PM in reply to: jad.dellel
    it is ok
    mais moi pour le parametre regionaux c'est canada français. mais je vois que ça fonctionne pas. pour acceder aux structures types et  la norme canadienne CISC je dois utiliser l'anglais.
    merci mais je pense que vous devez corriger ça pour vos client au Quebec
    Product Support
    jad.dellel
    08-10-2012 02:01 AM in reply to: wadii.bouzemmi
    Utiliser les preferences indiquees pour generer la structure, ensuite modifier les sections de votre treillis.
    Jad DELLEL
