Autodesk Robot Structural Analysis
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
LINEAR LOADS
- Highlight
- Email to a Friend
Hi. Whenever i have a linear load, be it live, dead or whatever, and I show the loads anyways in the model, the linear loads are revealed even if they do not apply to the part I am showing. Please see figure. Is there a way to stop the linear loads from showing unless it is the part they are applied to.
Structural Design Engineer
MZ & Partners Engineering Consultancy
Re: LINEAR LOADS
- Highlight
- Email to a Friend
Could you send us your model (Compressed RTD file) please ?
Francois Augiere
Support Specialist
Product Support
Autodesk, Inc.
Re: LINEAR LOADS
- Highlight
- Email to a Friend
Hi. I tried to send a sample model *.rtd, but it says that the extension is unsupported. I also tried to use winrar but I received the same thing. How should I upload it.
Re: LINEAR LOADS
- Highlight
- Email to a Friend
Maybe try to rename it first (*.txt instead of *.RTD), then zip it
Francois Augiere
Support Specialist
Product Support
Autodesk, Inc.
Re: LINEAR LOADS
- Highlight
- Email to a Friend
still doesn't work. it does not recognize *.rar, and even if i change the extension to *.txt it takes it as *.txt.rtd.
Re: LINEAR LOADS
- Highlight
- Email to a Friend
Please check the message i sent you in Private Message
Francois Augiere
Support Specialist
Product Support
Autodesk, Inc.
Re: LINEAR LOADS
- Highlight
- Email to a Friend
I have attached it as you said. Thanks for your assistance. I hope this helps to clarify my question.
Re: LINEAR LOADS
- Highlight
- Email to a Friend
This is due to the fact that "linear load 2p" is not a kind of load applied to objects/panels, it is defined by 2 points coordinates. So when you use "Edit in a new window" with panel 9 selected, the linear load 2p is still shown (as part of the same load case).
You could use instead load on edge, with a new definition of the lower slab (see attached modified RTD file, and screen captures)
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Francois Augiere
Support Specialist
Product Support
Autodesk, Inc.
