• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Contributor
    Dirgs
    Accepted Solution
    Iterative Modal Analysis
    351 Views, 6 Replies
    07-11-2012 11:25 AM
    Hello!
    I'm trying to do a iterative Modal (Pseudo Mode) analysis of a roof steel structure, but I'm getting error nº101 (incorrect data: Improper element number).
    I don't understand what's gone wrong or why the element number is relevant for the analysis. I also try between different mass matrix type but it always stuck in same error nº 101...
    Can you help please.
    Please use plain text.
    Active Member
    Re: Iterative Modal Analysis
    07-11-2012 05:13 PM in reply to: Dirgs
    Do a renumbering begining at 1000 just in case.
    Lumped without rotations should be a good choice for a bar made structure. Disable sturm check. See if it helps
    Product Support
    Artur.Kosakowski
    07-11-2012 11:07 PM in reply to: Dirgs
    Please attach the rtd file.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    Dirgs
    07-12-2012 01:33 AM in reply to: Dirgs
    I try the renumering of bars, it doesn't work.
    Also try the diferent add mass types, global and dynamic, with same result, error nº101...
    In attach you can find the model,
    Thanks Arthur
    Product Support
    Artur.Kosakowski
    07-12-2012 02:56 AM in reply to: Dirgs
    Please set the solver as Auto.
    If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    Dirgs
    07-12-2012 03:23 AM in reply to: Artur.Kosakowski
    A usual direct modal analysis with eigenvalues work fine, for this particular case.
    I'm starting to settle the modal analysis type on this substruture to lead to a global spectral analysis much more consuming. For what I understand, for bigger and complex models, obtein natural frequencies with iterative PCG_RITZ method will be the best choice, but I'm stuck in this error...Ii cannot know why.
    Product Support
    Artur.Kosakowski
    07-17-2012 05:53 AM in reply to: Dirgs
    The iterative multilevel solver is not compatible with rigid links (error 101). For large models (above 500000 d.o.fs) I would recommend use of the multi-threaded solver with block subspace iteration for 50-100 modes or Lanczos for more modes.
    Artur Kosakowski
    Support Specialist
    Product Support
    Autodesk, Inc.
