Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Iterative Modal Analysis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello!
I'm trying to do a iterative Modal (Pseudo Mode) analysis of a roof steel structure, but I'm getting error nº101 (incorrect data: Improper element number).
I don't understand what's gone wrong or why the element number is relevant for the analysis. I also try between different mass matrix type but it always stuck in same error nº 101...
Can you help please.
Re: Iterative Modal Analysis
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Lumped without rotations should be a good choice for a bar made structure. Disable sturm check. See if it helps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please attach the rtd file.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I try the renumering of bars, it doesn't work.
Also try the diferent add mass types, global and dynamic, with same result, error nº101...
In attach you can find the model,
Thanks Arthur
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please set the solver as Auto.
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
A usual direct modal analysis with eigenvalues work fine, for this particular case.
I'm starting to settle the modal analysis type on this substruture to lead to a global spectral analysis much more consuming. For what I understand, for bigger and complex models, obtein natural frequencies with iterative PCG_RITZ method will be the best choice, but I'm stuck in this error...Ii cannot know why.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The iterative multilevel solver is not compatible with rigid links (error 101). For large models (above 500000 d.o.fs) I would recommend use of the multi-threaded solver with block subspace iteration for 50-100 modes or Lanczos for more modes.
Artur Kosakowski
Support Specialist
Product Support
