• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    Italy NYC 2008 Moment Resisting Frames with Concentric Bracings
    192 Views, 3 Replies
    01-20-2012 04:41 AM
    Hi All
    I have some difficulties in order to understand if and how I can use the Italy NTC 2008 Add On for Moment Resisting Frames with Concentric Bracing. The Italian regulation lets you use this kind of structure but It seems that is not possible to use this kind of structure in the current version of ICK.
    I have to verify the hierarchy of resistance for columns and beams considering the structure as moment resisting frames and the bracings as structure with concentric bracings ?
    Please use plain text.
    Re: Italy NYC 2008 Moment Resisting Frames with Concentric Bracings
    01-21-2012 10:15 AM in reply to: GabrieleNovembri1027
    :smileyvery-happy: NYC instead of ICK Thanks to spell check :smileyvery-happy:
    Member
    Massimo.Speziani
    01-23-2012 05:23 AM in reply to: GabrieleNovembri1027
    Hi Gabriele,
                           According to Eurocode 8 point: 6.10.2 Moment resisting frames combined with concentric bracings
    (2)The moment resisting frames and the braced frames should conform to 6.6, 6.7 and 6.8.
    In order to check that situation, the solution is a two steps process. First bracings verification according to 7.5.5 and then verification of the MRF (beams and columns) according to 7.5.4. In case, if you would like to check beams according to 7.5.4.1 and according to formula 7.5.14 you need to change the member definition one time. This is not be done automatically for now.
    Best Regards
    01-24-2012 06:49 AM in reply to: Massimo.Speziani
    Hi Massimo.
    Thanks for the information.
    Gabriele
