Is there a way to "clean" the Robot model associated with the Revit one?
Everytime time I send the model from Revit to Robot I have to delete a node which corresponds to an old footing that I used to have in Revit. I've deleted the footing in Revit, but somehow the corresponding node in Robot sticked to the model, so I have to delete this node manually everytime.
Furthermore, Robot no longer recognizes some of the beams' materials, which have always been the same and is also the only steel material in the project. I also have to manually reassign the proper material to those beams..
Are these bugs? Is there a workaround?
Tks
Rafal.Gaweda
Autodesk Support
Autodesk Support
Try to clear the data shown below, save revit file and then export it to Robot.
Rafal Gaweda
That worked perfectly!
