• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    pevelor
    Accepted Solution
    Integration REVIT <-> ROBOT
    410 Views, 6 Replies
    02-17-2012 04:13 AM
    Hi
    I am trying to get update my revit model from robot. Everything is working just fine, except transfer of reinforcement.
    What can I do to fix this problem?
    I update from revit as shown below
    I use the following settings
    And I get the following message
    And the following error
    Any help on this matter would be much appreciated:-)
    In addition, I have not figured out a way to update my robot model from revit. Is this even possible, and if so how is it done?
    Regards
    Peder
    Please use plain text.
    Product Support
    Re: Integration REVIT <-> ROBOT
    02-17-2012 04:18 AM in reply to: pevelor
    Please upload robot file
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Valued Contributor
    pevelor
    02-17-2012 04:46 AM in reply to: RG_Adsk
    thanks for looking into it.:smileyhappy:
    I cant seem to be able to compress the file enough this time, even without results
    Please refer to the followin thread which has the same model: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Structure-verification/td-p/3334637 -  Ole Deviks vei 6.zip 246 KB
    Product Support
    02-17-2012 06:07 AM in reply to: pevelor
    The movie how it works on my side here:
    https://www.filemail.com/dl.aspx?id=DFBPROFUIDGSNHH
    NOTE: The issues can be related to reinforcement You generated in Robot.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Valued Contributor
    pevelor
    02-20-2012 01:25 AM in reply to: RG_Adsk
    Thanks for the video upload.
    The prosess you demonstraded is exactly the same as I have done.
    So I reinstalled revit which did not help. But when I uninstalled it and intalled it again it works perfectly.
    Thanks again:smileyhappy:
    Valued Contributor
    pevelor
    02-20-2012 06:43 AM in reply to: pevelor
    Hi
    I have a follow up question,
    Do you have solution for transfer of wall and floor reinforcement from Robot to Revit?
    Product Support
    02-21-2012 03:21 AM in reply to: pevelor
    Currently it is not possible to transfer plate and walls reinforcement from Robot to Revit.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
