• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Active Contributor
    sorgjee
    Accepted Solution
    Instability summary
    108 Views, 2 Replies
    02-29-2012 06:56 AM
    Is there any way of having all instabilities (with node number, type, and direction) being output in a report format? This would make bug hunting in complex models a lot more efficient. If not could this be added to some wishlist?
    E
    Please use plain text.
    Product Support
    Re: Instability summary
    02-29-2012 07:09 AM in reply to: sorgjee
    Please check the contents of the text file robwin.log which can be found in the following folder:
    Win XP:
    c:\Documents and Settings\username\Application Data\Autodesk\Autodesk Robot Structural Analysis 2012\tmp\
    Win Vista and Win 7:
    C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2012\tmp\
    If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Pawel Pulak
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    sorgjee
    02-29-2012 10:02 AM in reply to: pp2008
    Beautiful!
