• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Active Contributor
    Instability errors in model with no releases
    396 Views, 9 Replies
    10-08-2012 02:11 AM
    I have a model which was created by a colleague of mine and i've now taken over. It was giving instability errors, and i could not get rid of them so i went through and deleted all the releases but i was still getting instabilities.
    Is there any common reason that this might happen? If not would someone be able to have a look at the model and see if they can find any errors in it that might be causing this? I will upload it somewhere if so.
    thanks!
    Please use plain text.
    Product Support
    Active Contributor
    Re: Instability errors in model with no releases
    10-08-2012 02:47 AM in reply to: RG_Adsk
    Product Support
    10-08-2012 08:33 AM in reply to: PaulGrimes2282
    IN short - too many or wrong releases in some (many) nodes.
    It will take me some  time to correct.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Contributor
    10-09-2012 02:07 AM in reply to: RG_Adsk
    Yes - i thought this might be the case. But when I removed all the releases I was still getting instability errors - is there some further underlying problem?
    file with no releases:
    https://www.yousendit.com/download/TEhYZm1kbThCMTd2WnRVag
    Thanks for looking into it.
    Product Support
    10-09-2012 02:28 AM in reply to: PaulGrimes2282
    Should I correct file with releases or not?
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    10-09-2012 02:29 AM in reply to: PaulGrimes2282
    merge nodes 796 1402
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    10-10-2012 01:53 AM in reply to: RG_Adsk
    Model corrected http://wtrns.fr/oZNEZn3anfttNz - check diagrams etc.
    I have removed some releases, new releases added : PP  and Fixed Pinned no rx ; nodes merged.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Active Contributor
    10-10-2012 08:47 AM in reply to: RG_Adsk
    Hello, thanks for your help so far. However when I open your fixed model and run it – I get a warning that says ‘Matrix is not positive definite’. This suggests that the model is unstable? (see image below)
    <error1.PNG>
    If I run the analysis with the DSC Algorithm turned on then I am still getting unstable nodes where they should be stable. (see image below)
    <error2.PNG>
    Is there any reason why this would be happening for me, but the model runs cleanly for you?
    Thanks!
    Product Support
    10-10-2012 09:05 AM in reply to: PaulGrimes2282
    Read the warning to the end ... check buckling.
    Critical coeffs below 1 for nonlinear selfweight - check "upper branches of trees"
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
