Imagine a cantilevered perfectly vertical column with vertical axial load at its top. If you look at the deformation it is only the shortening of the column. If you run buckling analysis of such column the shape of the buckling mode is different - column moves sideways.
What you can do is top replace the original 'shape' of the model with the one that resembles the shape of the selected buckling mode (e.g. mode 2). If you apply the same vertical load on such deformed model (case 2) you can see that there are some additional side movement of the column due to this vertical load. In the example the max. horizontal 'deformation' of the column is assumed as 1 cm. If you check the value of the horizontal outplacement of node 3 for case 2 you can see it is 1.3 cm.
Artur Kosakowski
