• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Robot Structural Analysis
    Valued Contributor
    jo2ny
    Accepted Solution
    Incorrect masses ?
    235 Views, 3 Replies
    11-12-2012 03:57 AM
    I'm having trouble with the masses participating to modal analysis.
    In order to avoid any other errors i defined a single load (33 Masses) specialy for load to mass conversion.
    I set the Direction -z, coef. = 1.00 , ->global masses
    The 33Masses load is uniformly distributed at the roof level.
    After i run the calculation, in the Dynamic Analysis Results table i get the Total Mass = 14442 Kg.
    The mass participation for the first mode (UY direction) is only 65%.
    BUT, the total UZ reactions for 33Masses load is 61kN;
    Q1: Why is the toatal weight from 33Masses (=61kN) converted in 14442 Kg mass? Shouldn't it be ~6100 Kg ?
    Q2: The roof elements are the only ones loaded with 33Masses. I also added a ridgid diaphragm at the roof level. Why is only 65% of the total mass participating in the first 3 modes?
    I couldn't attach my model but you can find it here. http://dl.transfer.ro/transfer_ro-12nov-10a5ae9b2b8744cd.zip
    Thank you in advance!
    Please use plain text.
    Product Support
    Re: Incorrect masses ?
    11-12-2012 04:07 AM in reply to: jo2ny
    It is like that - see below:
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    11-12-2012 04:09 AM in reply to: jo2ny
    Take a look at screen shot above - 98/100 % after first 2 modes without considering selfweight.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Valued Contributor
    jo2ny
    11-12-2012 04:53 AM in reply to: RG_Adsk
    Thank you so much!
