• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    New Member
    Tarrataca
    Incorrect Data - Error Nr.5000
    437 Views, 5 Replies
    01-30-2012 12:42 PM
    During the calculation of a structural model (constitute only by bars elements), when in Buckling Deformation (Analysis Type), I switch off the option Omit case for structure with deformations, an error Nr. 5000 happens, and the calculation process is stopped. This error only happens in this situation, since the model is calculated normally when that option is on.
    Is there any way of overpass this error ?
    Best regards,
    Tarrataca
    Please use plain text.
    Product Support
    Re: Incorrect Data - Error Nr.5000
    01-31-2012 12:10 AM in reply to: Tarrataca
    Error 5000 generally corresponds to memory problems.
    If restarting Robot before running your model does not help please attach your model (compressed to ZIP to reduce its size) to check it in more detail.
    Pawel Pulak
    Support Specialist
    Product Support
    Product Support
    02-02-2012 06:18 AM in reply to: pp2008
    The model was not attached but if it is the same case are reported via reseller then the reason is in using multi-threaded solver for this type of analysis. Please change to Automatic or Sparse in Tools>Job Preferences> Structure analysis
    If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
    Pawel Pulak
    Support Specialist
    Product Support
    Valued Contributor
    jo2ny
    09-24-2012 01:48 AM in reply to: Tarrataca
    I got the same error, I read the discussion above, changed the analysys method to Sparse, and back to Automatic.
    When set to Automatic, Robot just crashes. When set to Sparse, i get the 5000 error.
    What can I do now?
    I attached the model.
    Thanks in advance
    I'm running Robot x64 on Win 7 x64
    Intel Core 2 Quad Q9640 @3.00 GHz
    8 Gb Ram
    Product Support
    09-24-2012 02:02 AM in reply to: jo2ny
    Ionut
    Change structure type on SHELL ; 3D frame with FEs can not be calculated as FRAME 3D structure.
    Rafal Gaweda
    Product Support
    Valued Contributor
    jo2ny
    09-24-2012 03:19 AM in reply to: RG_Adsk
    Yep, worked!
    Thanks again for your swiftness and precission.
    Amazing...
