Autodesk Robot Structural Analysis
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Inaccuracy in truss insertion point
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
When I'm using Robot's built in truss function and try to specify my insertion point, Robot seems to be incapable of inserting the truss just where I want it. My insertion point has both a node and intersecting axes, but the truss is still inserted a minute distance from the intersection (see attached image). This, of course, produces a useless mesh. How can I fix this?
Re: Inaccuracy in truss insertion point
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Unfortunately the picture itself doesn't contain all information that I need but the following should work:
1. Insert the truss anywhere making sure that the truss is in the right plane
2. Select all nodes and bars of the truss
3. Move it indicating the translation vector from the reference node of the truss to its intended location
Artur Kosakowski
Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It still ends up a small distance from where I want it. It probably doesn't matter, but now it ends up on the other side of where it should be...
I've attached my model in case you'd like to give it a go. I'm trying to position it at LVL3,11,C-D, but it seems to be the same story all over.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
1. Lack of accuracy in the original model (elements not aligned with the structural axis 11)
2. Correction
3. Move
Mind to deal with the overlapped elements (existing beams and to[p chord of the truss after moving it to the target location).
Artur Kosakowski
Support Specialist
Product Support
