• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    Re: Improving the speed ofmy computer (hp Z800 workstation)
    11-20-2012 02:27 AM in reply to: RG_Adsk
    Dear Rafal
    I am very sorry , pls resend the last capture as attached
    Refaat
    Please use plain text.
    Product Support
    11-20-2012 02:41 AM in reply to: refaat
    Attached
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    11-20-2012 03:30 AM in reply to: RG_Adsk
    Dear Rafal
    really appreciate you effort and thank you very much
    Refaat
    11-22-2012 12:12 AM in reply to: refaat
    Dear Rafal
    In the attached model , I have noted that some simple cases aren't included in the (Automatic Combination"ACI318-2002 ) such as case number (1 , 2 ,3....etc) and some of them are repeated , also there are some combination cases such as (1.20DL+1.60 LL) aren't included in combination case .
    Please   see the attached capture .
    http://www.2shared.com/file/X9or4OSn/Strucutral_meshed1-Disrgard_de.html
    Kindly , Could you help me to get all combination cases according to ACI318-02?
    Thanks a lot
    Refaat
    Product Support
    11-22-2012 05:06 AM in reply to: refaat
    Thanks for reporting.
    Just component definition (name=display is wrong - internally everything is OK).
    COnvert code combinations onto manual ones to see that everything is OK for calculations.
    Example:
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    11-22-2012 05:13 AM in reply to: RG_Adsk
    Printout, printout preview from this table contains correct definitions.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    11-22-2012 06:15 AM in reply to: RG_Adsk
    Dear Rafal
     I am very apologize .
    Please , send me the capture  in your last post as attached .
    Refaat
    Product Support
    11-22-2012 07:11 AM in reply to: refaat
    Attached
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    11-22-2012 07:21 AM in reply to: RG_Adsk
    Dear Rafal
    Many  thanks for your fast response
    Refaat
    11-25-2012 04:40 AM in reply to: refaat
    Dear Rafal
    In the attached file, I have calculated the required reinforcement for RC-Wall using (ACI318-08M), for first run without using the Amin , I found out that in the vertical reinforcement, the required steel area is less than the minimum ,after that I used in the second run Amin for finite elements, their steel area is less than minimum and greater than zero but I have noted that ROBOT used twice the steel area minimum for some finite elements .
    Pls , could you verify this point ?
    Note : Kindly , if there is any capture . please send it as attached
    http://www.2shared.com/file/MRrHPDWz/Strucutral_meshed1-Disrgard_de.html
    Thanks a lot
    Refaat
