• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Product Support
    Re: Improving the speed ofmy computer (hp Z800 workstation)
    11-12-2012 04:31 AM in reply to: refaat
    If possible please attach screen shot with your Modal analysis settings.
    Maybe you use different  method or ...
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Please use plain text.
    Distinguished Contributor
    11-12-2012 07:06 AM in reply to: RG_Adsk
    Dear Rafal
    Attached is the screen shot with modal analysis parameters
    Thanks alot
    Refaat
    Product Support
    11-13-2012 06:33 AM in reply to: refaat
    Thanks, developers are checking it.
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    11-17-2012 11:30 PM in reply to: RG_Adsk
    Dear Rafal
      I am still working  on the same model . But I couldn't  able to get participation (90%) when I used the fixed supports under columns & walls instead of the raft foundation with springs.
    Pls, Could you help me to get (90%) ? , attached is my model with fixed supports .
    http://www.2shared.com/file/l-2ZjR1X/Strucutral_meshed1_fixed_suppo.html
    Thanks a lot
    Refaat
    Product Support
    11-19-2012 03:29 AM in reply to: refaat
    1. Selweigtht as mass for modal analysis duplicated in your model (1: from modal analysis settings, 2: load to mass conversion)
    2. Results for such settings:
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    Product Support
    11-19-2012 07:17 AM in reply to: RG_Adsk
    Different settings:
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    11-19-2012 10:40 PM in reply to: RG_Adsk
    Dear Rafal
    Pls , Could you resend both of the screen shot , because they don't  appear on my computer.
    Thanks a lot
    Refaat
    Product Support
    11-20-2012 12:12 AM in reply to: refaat
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
    11-20-2012 01:03 AM in reply to: RG_Adsk
    Dear Rafal This duplicated (mass of self weight) can be happened only when I have fixed supports ? if your answer (No) , pls , can you show me how can I know there is any duplicated in my model ? Thanks a lot Refaat
    Product Support
    11-20-2012 02:13 AM in reply to: refaat
    See below:
    Rafal Gaweda
    Product Support
    Autodesk, Inc.
