• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Robot Structural Analysis
    Distinguished Contributor
    Improving the speed ofmy computer (hp Z800 workstation)
    643 Views, 45 Replies
    11-04-2012 11:30 PM
    Dear Sir
    Can you help me to improve the performance of my computer(the speed), where I am doing dynamic analysis for concrete tower using (200 mode) , the finite element size(1.00m) on the version (ARSApro2013), whereas the program takes more than (60 hours) until I can get the analysis results.
    Knowing that my compture(hp Z800 workstation) specifications as attached.Although , I've developed  it from (6 GB RAM) to (48 GB RAM) and don’t note any improvement in performance (increased speed).And the graphics card specifications as following :
    GV-R795WF3-3GD
    AMD Radeon HD 7950/PCI-E 3.0
    3072 MB GDDR5/384 bit
    Could  you guide me how to increase the efficiency of the computer (increase speed) or what way I can get the results of the analysis faster than (60 hours)?
    Refaat
    Please use plain text.
    Product Support
    Re: Improving the speed ofmy computer (hp Z800 workstation)
    11-05-2012 12:33 AM in reply to: refaat
    1. Send us model
    2. Turn off saving quadratic combinations results in job preferences and check.
    Rafal Gaweda
    Product Support
    11-05-2012 06:37 AM in reply to: RG_Adsk
    Dear Rafal
    Attached is my model
    Thanks in advance
    Refaat
    http://www.2shared.com/file/uM-iS2RQ/Refaat_05112012.html
    11-05-2012 07:34 AM in reply to: RG_Adsk
    Dear Rafal ? Attached is my model ? Thanks in advance Refaat ? http://www.2shared.com/file/uM-iS2RQ/Refaat_05112012.html
    Product Support
    11-05-2012 11:29 PM in reply to: refaat
    ~5h25min
    settings below
    Rafal Gaweda
    Product Support
    11-06-2012 03:23 AM in reply to: RG_Adsk
    Dear Rafal
    Even , I turn off saving quadratic option as you suggested but still my compture running since  more than 16 h ago.
    So, what can I do ?
    Thanks alot
    Refaat
    Product Support
    11-06-2012 05:10 AM in reply to: refaat
    Log:
    17:48:03 - Structure preparation for analysis #0
    18:14:48 - End of preparation for analysis #0
    18:14:48 - Start of analysis #0
    18:14:48 - It is suggested to use 'DSC algorithm' in case of dynamic and non-linear analysis of structure containing released directions.
    The DSC algorithm option can be switched on in the 'Job preferences' dialog box (the 'Structure analysis' tab).
    Do you want to continue? #0
    18:44:19 - For 8 modes the mass participation factor is equal 70.19
    Do you want to continue the increasing of modes?
    [Press ESC to ignore all warnings] #0
    18:49:56 - For 17 modes the mass participation factor is equal 76.66
    18:56:46 - For 26 modes the mass participation factor is equal 76.70
    19:04:45 - For 29 modes the mass participation factor is equal 86.65
    19:13:57 - For 44 modes the mass participation factor is equal 87.23
    23:38:36 - End of analysis #0
    My comp:  HP z600
    Rafal Gaweda
    Product Support
    11-06-2012 10:45 PM in reply to: refaat
    Dear Rafal
    Do you have any other advice to overcome this problem ?
    attached is basic information about my computer.
    Refaat
    Product Support
    11-07-2012 12:21 AM in reply to: refaat
    PLease attache log file
    "c:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2013\Tmp\robwin.log"
    What happens after changing solver onto multithreaded ?
    Rafal Gaweda
    Product Support
    11-07-2012 12:59 AM in reply to: RG_Adsk
    Dear Rafal
    My computer is still runnig , once it finished I will send to u the (Log file ) and also I will try with multithreaded solver .
    Also , I have noted that your computer has two processors while mine has only one.
    Does this affect ?
    Thanks alot
    Refaat
