Importance Factor Definition (Wind Loads Generation)
Refaat
Advisor Advisor
Refaat
Kindly help me
How to define importance factor ( I =1.25 ) to be able to generate wind loads by ( CBSpro 2013) using ( ASCE7-02) ?
Pls , see the attached capture
Refaat
Rafal.Gaweda
Autodesk Support
Autodesk Support
Importance factor is calculated inside the program using equations taken from ASCE -7-02 and depends on Building category and k (which is calculated using Velocity and Hurricane prone region option). All of needed parameters are available on the dialog.
Rafal Gaweda
